All Cads
Author Topic: Replacing vacuum lines on a 1970 Cadillac  (Read 443 times)
Offline Bill Balkie 24172
  • 1970 Coupe DeVille/ 2009 CTS
« on: February 21, 2020, 07:29:50 PM »
Hello Again ,
     I am in the process of replacing most if not all  of the vacuum lines in my 50 year old Cadillac . I have noticed that the vacuum hoses coming off the control valve have a colored streak that is very helpful . My question is what is the best type of vacuum hose to use ? I hear good things about UPGR 8 it is a  combination  of silicone compounds and fabrics .  Some are made of neoprene.  Does any body reproduce the hose with the colored streak ? Finally how many different diameter hoses are used on the engine .  I noticed that the original hoses are ribbed ( lines running the length of the hose. Is there anything particular to look for or a certain brand that works better in the system ?
 Thank you ,
           Bill
Bill Balkie
1970 Coupe DeVille
2009 CTS
Offline MikeLawson
  • Name: Mike Lawson
Re: Replacing vacuum lines on a 1970 Cadillac
« Reply #1 on: February 21, 2020, 08:54:42 PM »
Old Air Products sells this universal vacuum line kit which has striped hoses:
https://www.oldairproducts.com/product/23-0905-vacuum-hose-universal-fit-kit-8-hoses
I'm sure there are other suppliers as well if you search around a bit.
Offline Scot Minesinger
« Reply #2 on: February 21, 2020, 09:30:32 PM »
Bill,
Good idea, one at a time is best.
The climate control hoses that are striped are made like a harness and are joined together on the inside at dash climate control and connector at firewall.  Best to disconnect from each actuator, snip off the ends (1/4") and reconnect.  They hold up well on interior, and the harness makes it fool proof.  Under the hood replace them all, especially the ones thru the firewall.
« Reply #3 on: February 22, 2020, 08:05:00 PM »
Hello Scot ,
      Sounds like a good idea to me .  Thank you for all your help in the past . I took the car out today and what a good feeling to have that emergency brake release when I put the car in gear .
   Thanks again for your help in the past,
       Bill
Bill Balkie
1970 Coupe DeVille
2009 CTS
« Reply #4 on: February 22, 2020, 08:22:54 PM »
Hello Mike ,
     Thank you for the source . I’ll give them a call this week.
 Bill
Bill Balkie
1970 Coupe DeVille
2009 CTS
