Founded 1958
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Forum Rules
Calendar
Login
Register
CLC Home
Forum Rules
General Discussion
(Moderators:
Lars Kneller 8246
quadfins
Barry M Wheeler #2189
Bill Hedge CLC 14424
Grr. A wasted day
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Grr. A wasted day (Read 525 times)
dochawk
Grr. A wasted day
on:
February 23, 2020, 06:21:56 PM »
Nice weather today, shirtsleeve even in Las Vegas.
So it seemed like a good day to try to get the '72 going, having realized the tank was probably empty on my prior tries where it kicked over and sopped after a second or so (priming the carb each time).
So to get room, the first step was to get the '93 ETC out of the way.
It's been sitting with the battery disconnected since October, when I found the Fleetwood. It's waiting for me to pull fender, door, radiator and alternator from the '95 parts car.
So I connected my monster charger. (When the last one went out, I bought one big enough start Frankenstein's monster, with 40 amp sustained and 200A engine start modes).
But before that, it took about an hour to reconnect the positive post--it had dropped the spacer disk, and my wrenches fell in a few times. After another hour of charging, I still couldn't get more than a click, and pushed it partway into the driveway with a daughter at the brake, just in case.
I moved the charger to the '72, which I'd topped off maybe a month ago.
Put it in neutral to push it out and get more room, as I've done many times over the years . . . and nothing. It won't move.
So I resign myself to the reduced room (I still have maybe two feet between it and the workbench; it's a '68 house). I pour a couple of gallons of gas in, with minimal spilling form the funnel.
And after a couple of hours charging, I still don't get more than a click.
grr.
so in another 20 minutes or so, it gets one last try. I *really* don' want to have to deal with jacking it up to get at the starter again . . .
*one* of these days, both of them will be on the road again.
grr
Logged
1972 Eldorado convertible, 1997 Eldorado ETC (now awaiting parts swap from '95 donor), 1993 Fleetwood but no 1926 (yet)
Re: Grr. A wasted day
Reply #1 on:
February 23, 2020, 06:25:26 PM »
I ran my 1970 DVC out of gas once. These 26 gallon tanks often take 5 gallons to allow a start after running out of fuel. They still should turnover though. Cables clean?
Logged
Fairfax Station, VA 22039 (Washington DC Sub)
James Landi
2007 XLR
Reply #2 on:
February 23, 2020, 06:34:01 PM »
Don;t trust those an old ground cable. You can have a very capable starter, a relatively willing battery, and a "figuratively" smoked ground cable with insulation that looks fine but has stranded wire that has turned to white powder at the terminal end underneath the insulation. Try a jumper cable from the battery ground to a clean unpainted engine bracket and see if you get more than a discouraging click. Just may be the problem. James
Logged
cadillacmike68
Still crusin'
CLC Number: 15823
Reply #3 on:
February 23, 2020, 09:28:14 PM »
Reminds me of last summer when the 1996 Fleetwood refused to start. It was on the side of the house which had turned into a swamp. That made a mess of getting into and out of it.
Now it is used weekly and sits in the driveway under a cover.
Logged
"Cadillac" Mike
Reply #4 on:
February 24, 2020, 09:28:18 AM »
U just needa bigger garage...
Logged
Administrator
CLC Number: 18992
Reply #5 on:
February 24, 2020, 05:31:36 PM »
The bigger the garage, the more stuff to stick in it, and fill it up.
My small garage was coordinated and everything in its' place. Now I have a bigger garage, and there is still stuff in their correct places, but, boy, I have a lot more stuff, and trouble finding places to put everything, as I hate tossing out good stuff.
Bruce.
Logged
dochawk
Reply #6 on:
February 24, 2020, 05:39:19 PM »
I *want* 15 car garage.
I'm just not willing to have a mortgage again to do it . . . once I can write a check for it, maybe . . .
This morning, after giving it a couple more hours on the charger and leaving it overnight, the little Eldorado read 12.9v.
And it still only gave single click.
Logged
Administrator
CLC Number: 18992
Reply #7 on:
February 24, 2020, 05:53:32 PM »
Check for a bad ground.
Remove and clean then replace the battery terminals, and the grounding strap to the frame/body.
With a fully-charged battery, the current still has to get through.
Try turning on the headlights and have someone look at the glow when you are hitting the start "button". If they are bright, then really dim, then there is a grounding problem. Lights don't need as much ground as the Starter Motor.
Bruce.
Logged
The most valuable antique is an old friend.
CLC Number: 4719
Reply #8 on:
February 24, 2020, 06:38:25 PM »
Since it has been sitting for a while, it might also be the starter solenoid contacts have gotten corroded.
Logged
BlackCads
Name: L Feininger
Reply #9 on:
February 24, 2020, 08:12:10 PM »
The joys of old cars!
Some days are great and everything goes smoothly and other days nothing goes right.
I've had many of both and in the final analysis I'm glad I stayed with the cars through all the ups and downs. I've learned a lot from my mistakes so every work session is also a learning experience.
Hang in there. Your patience and perseverance will ultimately pay off.
As my late father used to say "better days are coming".
Logged
Print
Pages: [
1
Go Up
« previous
next »
General Discussion
(Moderators:
Lars Kneller 8246
quadfins
Grr. A wasted day
Sitemap
1
2
3
4
5
6
7
8
9
10
11
12
13
All Cads
