1951 331 engine question
Started by DTBass, April 13, 2020, 10:59:40 AM
DTBass
So I’m still working on my early 331 motor. I’m not sure of the year but the Vin # starts with 51 so does that mean it’s a 1951 motor?  My second question is I need the lower portion of the bell housing that holds the starter.  Is that unique to the year the motor was made or can I use for example a 1949 piece.  Thank you guys for any help with this.  Also if anyone has a manual trans bellhousing for this motor I need one!  Thanks!
Doug
1917 Maxwell
1948 Oldsmobile
1954 Chrysler New Yorker
1957 Cadillac Series 62 Coupe
1966 Mustang
CadillacFanBob
Hello Douglas,
The MPL lists: group # 8.0289 part# 145-4140 Housing,clutch or flywheel, lower fits 1949-1954. The hollander interchange manual shows the same. I have attached picture from MPL illustration. I hope this helps you.
Bob
Frankfort, Illinois
Jay Friedman
Yes, if the Vin # starts with 51 it means it’s a 1951 motor.
1949 Cadillac 6107 Club Coupe
Decatur, Georgia
CLC # 3210, since 1984
DTBass
Great info thank you Bob and Jay!  Now if I could find a bellhousing for the synchromesh transmission I’d be all set.  I know they are very hard to find.
Thanks again!
Doug
I’m including my phone # just in case someone out there has the bellhousing I need.
631 988-1139
1917 Maxwell
1948 Oldsmobile
1966 Mustang
Jay Friedman
For the bell housing try 49caddymanemail addresses not permitted, CLC member Dennis Akerman in N. Hampshire, CLC member John Gately in Mass.  Also, Arizona Vintage Parts.
Decatur, Georgia
