Before commuting 2000 miles to the GN and 2 other nationals in 2015, I spent 2 solid months getting my 79 Eldo roadworthy again. There is an 18 page description of adventures here. At the very minimum, take care of tires, brakes, timing chain, and the EFI system, to avoid unrecoverable damage.
Bruce and Bruce, thank you for the replies @Bruce Roe, so many questions pop up my head when I watch your pictures and read the descriptions.The main thing for now is that I tried to replace the injector seals yesterday and it was a disaster. Gas is squirting out from everywhere now....... So I only made it worse.What I noticed was that the seals in the replacement kit are different from the (original) ones that were installed.I will make some pictures tonight when I will redo the whole operation again.The fuel pump relay looks like a very smart solution. When I convert to LPG, anyway I will have to be able to switch the pumps on and off, so installing a relay gives me that opportunity.Another thing is the ECU. What I wonder is if it isn't a better idea to use a modern replacement ECU like a MegaSquirt or equivalent.To keep two ECU's sounds a bit silly to me and what when there is nobody around anymore to repair them?I saw that TJ Hopland has an aftermarket ECU in his Eldorado.
