Dual carbs on a 1957 Eldorado Biarritz
Started by thomas1245@aol.com, April 24, 2020, 07:01:43 PM
thomas1245@aol.com
I am restoring a 1957 Eldorado Biarritz and I wan to get the correct dual carb setup on it. In 1957 were the dual carbs Carters or Rochesters and does anyone know the correct casting number for the intake manifold. We have a setup that is supposed to be for a 1957 but before we install it we want to be sure that it is correct.
Can't give you the numbers, but the car I worked on had Carter WCFB carbs.
Mike Josephic CLC #3877
Dave is correct, they were Carters.  Number for the single
carb was 2479S.  The additional carb for the 2 X 4 setup
was a no cost option.  Sorry but I don't show the listing
of a different carb # for that, although the two are usually
different.
Perhaps somebody with a '57 will see this and reply.
1955 Cadillac Eldorado
1973 Cadillac Eldorado
1995 Cadillac Seville
2004 Escalade
2011 Buick Lucerne CX
CLCMRC Museum Benefactor #38
My parts list calls for 2890S see attached.
P/N for manifold.   Goes by engine number sequence.   So need the build sheet.
SixDucks
Here you go....
I bought this one years ago for a project but decided on an aluminum Weiand intake instead. Please message me if this interests you.
Terry
Current:
1941 coupe
1962 Fleetwood
1988 Brougham
Previous:
1956 Series 62 Sedan
1963 Fleetwood
1975 Fleetwood Brougham D'Elegance
1989 Brougham
SixDucks
Here are images of my Weiand intake and original Offenhauser valve covers on one of my 390 engines.
Current:
1941 coupe
1962 Fleetwood
1988 Brougham
Previous:
1963 Fleetwood
1989 Brougham
