1959 Steering column off line
Started by Superior1959, April 27, 2020, 07:20:34 AM
Superior1959
Hi
Whats with 59 steering columns or is it just my commercial chassis funeral coach. I noticed it was out of square while restoring and not until pulling it out saw that it is manufactured offline, the bracket which holds it to the floor is made on an angle.What were they thinking ??? Photos show straight edge across A pillars and floor bracket  ???
Buck 💀
JayRudig390
My 59 coupe is the same.  You can adjust it a little bit with loosening of the collar however.
