1975 Fleetwood Eldorado Convertible Body Tag Question "77 11R PNT"
Started by Matt CLC#18621, May 10, 2020, 08:21:39 PM
Matt CLC#18621
77 11R PNT
Paint Code 77 is Roxena Red and next to it is code "11R," does that stand for Cotillion White Roof?
Thank you.
matt
i am 2nd
D.Smith
On the convertible the  77 11R  PNT    translates to Roxena red with a white top and body side moldings.
Remember on the Eldorados the body side moldings have a painted insert.   So the 11 is Cotillion white painted insets to match the roof.
It's an easy way to tell if a convertibles top color has been changed from new as well.
In the photo below is the tag from another 75 convertible.
That tag shows: 52 11R  PNT Bombay Yellow with white top and moldings.
Eric DeVirgilis CLC# 8621
#2
One of three suffixes were used with the color code for the upper structure of the car.
R = Roof (Convertible)
T = Vinyl Top
U = Upper Color (painted roof)
Vinyl/convertible roof colors generally weren't called by the full names given to the paint colors - so 11R was simply white convertible roof. The code 19T is black vinyl roof , not "Sable Black" vinyl roof.
As Dave says, body side moldings were color matched to the roof color - painted on Eldorado; on Fleetwood Brougham and DeVille d'Elegance, a different style molding was used with insert matched to vinyl roof color.
Matt CLC#18621
