63 Fin tail light
Started by Mike Barruzza, May 23, 2020, 03:52:48 PM
Mike Barruzza
We have a 63 combination coach, the fin lights are a single contact. Would like to change them to a double contact bulb to make them ; stop, turn, and tail. Problem is there is not enough room for a #1157 bulb to fit behind the lens. Has anyone changed theirs and what bulb # was used?  Thanks in advance.
russ austin
You need to be worried about heat build up. I have had a car come in with the fin lens melted from this mod.  Look into LED lights inside the fin. I dont need to mention just how rare the CC/75 63 fin lenses are.
R.Austin
Mike Barruzza
Hi Russ,
Thanks for the info, I'll keep that in mind.
