Author Topic: 1959 Six Window Going LED  (Read 452 times)
Offline BillR. CLC # 29203
  • Name: Bill Rodwick
« on: May 25, 2020, 04:55:47 PM »
My son and a friend working through the back lights. Bright!!!
Local airport will ask for a loaner if their landing lights ever go down. He He He
Stay well!!!
Bill # 29203
Bill Rodwick
CLC # 29203
Crew Member:  '59 Sedan Deville Six Window
Offline Cadman-iac
  • CLC Number: 32373
  • Name: Richard Cook
Re: 1959 Six Window Going LED
« Reply #1 on: May 25, 2020, 05:20:30 PM »
Those are definitely bright enough. And the nice thing is you won't have to worry about melting the lenses.
Offline 59-in-pieces
  • CLC Number: 17326
  • Name: S. Butcher
« Reply #2 on: May 26, 2020, 09:09:11 PM »
Bill
When you used the LEDs, was there room for the diffuser that came inside the red lenses.
Have fun,
Steve B.
S. Butcher
« Reply #3 on: May 27, 2020, 09:06:41 AM »
Steve B.,
Later today or tomorrow when I speak with my son back east I will post his response.
Stay well.
Bill
CLC#29203
Bill Rodwick
CLC # 29203
Offline J. Gomez
  • CLC Number: 23082
  • Name: J. Gomez
« Reply #4 on: May 27, 2020, 11:22:59 AM »
Steve B.,
Stay well.
Bill
CLC#29203
Bill,
Are you guys replacing the older thermal flasher or would you be adding the dummy load resistors to get the older flasher to work?
You have the three prong type flasher “L”, “+”, and “P” so be caution on getting a LED type flasher that is advertised as “3-prong” which in reality is a 2-prong with a “ground” for the electronics. The LED flasher would need to be a 3-prong plus the “ground” wire, I’ve used the CEC Industries EF33RL for my modification, just for reference.   ;)
Good luck..!
J. Gomez
CLC #23082
« Reply #5 on: May 27, 2020, 02:26:02 PM »
J. Gomez,
Stay well.
Bill
CLC#29203
Bill Rodwick
CLC # 29203
« Reply #6 on: May 27, 2020, 06:38:24 PM »
Steve B. and J Gomez,
No room for the factory diffuser.
Every wire, connector etc. is being replaced.
Stay well.
Bill R.
CLC # 29203
Bill Rodwick
CLC # 29203
