390 drain plug torque specs
Started by David Greenburg, June 03, 2020, 07:37:08 PM
David Greenburg
I have usually done drain plugs by feel, but getting ready for spring oil changes on my cars, I noticed that the torque spec for the ‘61 was increased to 30-50 ft lbs, which is substantially greater that the 25-30 spec’d for ‘60. I’m wondering if perhaps there were complaints of leaks with the earlier engines, and GM figured out it was okay to make them tighter. Although if that were the case, you’d think it would have been addressed in The Serviceman.
David Greenburg
'60 Eldorado Seville
'61 Fleetwood Sixty Special
Jon S
I would think 50 foot pounds would strip the threads on the oil pan.  I have never seen any mechanic at a dealership or service center ever use a torque wrench on a oil drain plug.
Jon
1958 Cadillac Sedan De Ville
1981 Corvette
2004 Mustang GT
Quote from: Jon S on June 03, 2020, 07:58:48 PM
In the fifties, the oil plus is located in a way a torque wrench cannot be used.
David Greenburg
50 did seem way too tight.  I went up to about 36 and stopped.  On the ‘61, there is room to get a TW on it, but I think as Roger notes, the ‘60 and earlier design doesn’t leave enough space.
David Greenburg
#4
I figure the more times the oil is changed, the less torque it takes to wear it out.
Just did the 61st oil change on the H...., I now use some of that blue gasket maker
to keep it sealed without too much torque.  Bruce Roe
Another reason why oversize plugs are available.   Nothing worse than a heavy-handed service attendant.
Jim Govoni CLC 20546
Maybe it should be (in) inch pounds, many things are on the early 40's cars?  Just a thought.
Jim
1953 Series 62
1966 Fleetwood
1969 deVille Convert.
1941 Series 63
Clewisiii
I made that mistake once. Not paying attention and I tightened down a cast valve cover using foot pounds instead of inch pounds.
Dan LeBlanc
Quote from: Jim Govoni CLC 20546 on June 09, 2020, 12:31:57 PM
Jim
That would be 4.16 Ft-LBS.
Dan LeBlanc
Thanks Dan, that sounds about right!
1953 Series 62
1966 Fleetwood
1941 Series 63
