Need a picture of the back side of a 47 fog light switch.
Started by Bob Hoffmann CLC#96, June 18, 2020, 05:25:15 PM
Bob Hoffmann CLC#96
Bob Hoffmann CLC#96
Guys,
Any help?? It could be the same 41 to 47??
  Thanks, Bob
Glen
Looks like the switch is a one year only.
Glen Houlton CLC #727
CLCMRC benefactor #104
Jeff Hansen
Bob,
Posting here and also emailing you for convenience.  I have seen multiple types of switches.  Some have used the '41 backup light switch for fog lamps; it'll work.  I believe this to be a correct type of switch for no other reason than it is actually labeled with "FOG" and "PARK" terminals.  I've left the photo large for detail purposes.
Glen,  the listing you show is for the headlight switch.  While the fog light switch draws power from the headlight switch, it is a separate switch and is listed in section 53.0165.  The same switch (593 6053) was used from 1941 - 1947.
Hope this is helpful!
Jeff Hansen
1941 6019S Sixty Special
1942 7533 Imperial Sedan
Glen
Jeff, Your right, my bad.  Thanks for finding the right info.
Bob Hoffmann CLC#96
Guys,
Here's a pic of mine. Help!!
Thanks, Bob
Jeff Hansen
Bob,
What is the concern with the switch you have pictured?  Whether it is authentic or whether it will work?  Or?
Jeff Hansen
harry s
The difference in Bob's switch is the fuse holder. I have seen some with and some without. I'm not sure sure why.     Harry
Harry Scott 4195
1941 6733
1948 6267X
2011 DTS Platinum
Bob Hoffmann CLC#96
Jeff & Harry,
I just wanted to make sure it was correct. I'm going to offer it to a guy that needs one. Thanks for your help.
Bob
