X frame question
Started by 5960Special, July 06, 2020, 05:39:43 PM
5960Special
Hello all,
For my own random trivia knowledge, are there any differences in the frames used for roofed cars vs convertibles for specifically 1959-60 cars or generally for the years the X frame was used? Was additional support used for the convertibles? Thank you for your help!
Steve Ehrin
1989 Cadillac Fleetwood SDN
2010 Cadillac CTS Sport Wagon
Clewisiii
Short answer yes and the Service manuals show the differences between the frames.  I am not near mine currently to take a photo.
cadillac ken
My 1958 Biarritz has a 1/2" x 1 1/2"(? didn't measure it) piece of flat steel stock welded to the bottom of the frame from the factory.
The fact that this piece of steel flat stock was not present caused me to walk on a 1958 Convertible that I looked at.  I suspected a convertible body (maybe even a coupe made into a convertible) that was not on a convertible frame.
Also, remember that the steel in the Convertible, especially in the sills is stronger, and supplements the Chassis in rigidity.
raugusti
Quote from: cadillac ken on July 07, 2020, 08:03:34 AM
I was just looking at these on my convertible last weekend and wondering if it was stock.  The way it was added on made me question it.
Scott
Scott Augustine
Colorado, USA
'58 Series 62 Conv.
'58 Eldorado Seville
I can understand you thinking it could have been an afterthought, but from what I have seen under some convertibles, I think they got the Apprentice to perform those tasks.   Some welds have been really horrible.
cadillac ken
Quote from: The Tassie Devil(le) on July 07, 2020, 08:41:12 AM
Very true.  I had to duplicate repair inner "rockers" and as I remember they were 11 gauge steel.  They had to be bent up in a hydraulic press brake.
Clewisiii
Frame looks the same.
Mounts are different
5960Special
Thank you all for your replies!
Steve Ehrin
Pomeroy41144
Are the Fleetwood 75s X-frame for 59-60?
Eric DeVirgilis CLC# 8621
Quote from: Pomeroy41144 on January 28, 2021, 01:53:09 PM
Yes. Commercial Chassis too.
Pomeroy41144
Andrew Trout
'61 Convertible has two small rods that connect from the bottom of the front bumper (were the outer and middle section meet), cross over in an 'x' pattern, and then attach to the back of the crossmember that holds the hood latch. '62 Convertibles don't have them, and some '62 Convertible owners like to jokingly use that as proof their cars are superior.
Rochester, NY
1961 Convertible
64\/54Cadillacking
Was there any differences in rigidity from the hard tops vs the convertibles? For instance more flexing and rattles? BTW anyone that owns an X-frame Cadillac, be it from 1957 all the way thru 64, have any of you noticed problems with how your Caddy rides and drives?
And to the ones that have owned multiple different Cadillacs from different decades, how would they compare?
Riding smoothness.
Noise/Vibration/Harshness.
Handling.
Tightness.
Quietness.
Currently Rides:
1964 Sedan Deville
Previous Rides:
1987 Brougham D' Elegance
1994 Fleetwood Bro
1972 Sedan Deville
1968 Coupe Deville
1961 Lincoln Continental
I've found 61-64 quieter and more resistant to interior rattles than 59/60 but otherwise drive & handle similarly. Basically a refined 59/60. Some of this is attributable to the extra sound deadening material and single exhaust that began in '61.
A 59/60 can become quite a bucket of bolts depending on how it was treated throughout its life- especially if the car had a frame off restoration in which case they are almost never the same.
Reviewers back in the day noted slight frame resonance @ around 60 MPH but disappeared at speeds above and below that which is consistent with my experience. This applies to all years of the X frame 59-64.
The one thing that separates the closed car from the Convertible is in the amount of material used in the critical areas to replace the roof.
The Sills are either made out of thicker metal, and in most cases, have internal bracing within the sill box section.   I have seen a GM Convertible that had an additional section of steel travelling the full length of the bottom of the sill, and this only increased the height of said sill by about 5/8".
My '55 Chev Convertible had a totally different chassis than the sedan, with a huge "X" Member, and yet it still flexed.
I have looked at other makes, and each uses different methods to counter the roof removal, and the Convertible is always a lot heavier.
