1958 Control Arm Shaft: How do I know if I did it right?
Started by wbdeford, July 15, 2020, 08:44:52 PM
wbdeford
Not having the correct tool, I improvised, but don't know if I spread the arm enough, or too much, or whatever...
Anyone know how to tell?  Pic shows the arm and the tools I used.
1958 Sedan de Ville
Past:
1956 Fleetwood 75 Sedan
1957 Fleetwood 60 Special
1960 Coupe de Ville
1966 De Ville Convertible
1970 De Ville Convertible
1971 Eldorado Convertible
1979 Sedan de Ville
1980 Seville
Great improvisation Bill,
If the bushings are sitting fully-seated in their holes, and the cross fits, then it should be good to go.
wbdeford
Thanks, Bruce.  Yes, the bushings cranked all the way down, though they were stubborn.  I sprayed the threads with penetrating oil as the shop manual recommends, but still took a lot of effort with each turn after the first few.
The shaft turns without too much effort, though not loosey goosey.
1958 Sedan de Ville
Past:
1960 Coupe de Ville
1979 Sedan de Ville
1980 Seville
Jon S
I don’t see the grease fittings for the bushings.
Jon
1958 Cadillac Sedan De Ville
1981 Corvette
2004 Mustang GT
novetti
The manual sometimes have reference dimensions for the width of the arm.
I have done that a few times, and is not an easy job. The shaft should offer resistance to spinning, but not get jammed.
54' Iris Blue (Preservation)
54' Cabot Gray (Restoration)
58' Lincoln Continental Convertible (Restoration)
58' Ford Skyliner (Preservation)
wbdeford
Jon S, I put the grease fittings on after this pic.
novetti, sounds like it's right then....it offers some resistance.  I probably should have checked how it operated before removing the old shaft.
Thanks, guys!
1958 Sedan de Ville
Past:
1960 Coupe de Ville
1979 Sedan de Ville
1980 Seville
