Torsion Bar adjustment on 69 Eldorado
Started by Loveofclassics78, July 27, 2020, 04:22:42 PM
Loveofclassics78
Good afternoon!
I did a measurement of the standing height of my Eldo. Based off the information in the shop manual, I’m about half an inch too low. I know how to adjust the torsion bar at the screw.  I just wanted to confirm, do I adjust the torsion bar while the car is on or off the ground?
Don
I do it off the ground especially if you want to go higher.   Already lots of stress and likely rust on that bolt you need to make it as easy as possible to turn it.   I have had some that even with several soakings of penatrant didn't hardly want to loosen so I didn't even try tighter.    On that car I ended up swapping the rear springs side to side and that was enough to even it out.
I thought the half shafts should be parallel to the ground, is
that wrong?  Do bounce it a bit before making the check.  If
the T bar tool is available, tension may be taken off the
adjuster to service it if needed, a little anti seize goes on the
threads of mine.  Bruce Roe
