Scarebird bracket for wilwood dual MC on 52 series 62
Started by Omarine, July 27, 2020, 09:42:01 PM
Omarine
Evening all,
So i went ahead and got the scarebird Bracket that’s supposed to work with wilwood 260-7563 on frame mounted master cylinders. Here’s the link:
https://scarebird.com/index.php?route=product/product&path=60&product_id=123
Does anyone have experience with this? Laying under the car, the push rod on the clevis comes straight out and so close to the frame rail that it doesn't line up with the bracket and new MC bore. The bracket itself also
Seems bulky which might interfere with pedal travel if not carefully mocked up.
It’s almost like the pedal needs and offset clevis to move the push rod away from the frame rail enough for straight travel into MC bore.
Little details that never seem to get mentioned in ads...
Thanks everyone, of course i promised the car for a photo op at a wedding this sunday, no pressure though...
Cheers
Oscar
1949 Harley Davidson FL
1952 Cadillac Coupe de Ville
1961 Chevy Impala 2 dr hardtop
Omarine
Well i guess i will be finding another alternative. Going to rebuild stock MC. Impossible with the bracket i got and also, the pedal offers about 1/2” of push rod travel. The willwood piston travels 1.1”, so there’s another reason.
Cheers
I have been through similar issues with other less popular cars.   Even if the pedal could travel would its position be reasonable?  Probably not, it would end up too high or too low or both.
On one project I looked at building some sort of a bell crank mechanism to get the travel and maybe mount things in a better spot but that was going to require a lot of mock up to figure out.
About the best route I found but didn't do yet was to do what they call a swing arm setup which may require a different or modified hole for the rod in the floor with a hydroboost.    Just isn't enough ground clearance to put a vac booster under the floor unless you have a very early car or a truck.    There are some kits for 50's chev trucks but they don't come with the pedal part so you would have to find an original which I never researched to see how hard that is to find or what mods would be required to fit it in the car I was working on.
Omarine
Thanks for the reply TJ, i was thinking of re addressing the issue maybe using sheet metal to bend up a template. It would need a nice wrap around curve to realign the new MC. Would love to get the car up in the air for that...
