1958: Front Spring Shims
Started by wbdeford, July 29, 2020, 07:35:32 PM
wbdeford
The right side of my car had a shim between the insulator and frame.  When I put new springs on it, should I reinstall the shim?  IOW, is it more likely there because of slight differences between the two springs, or is it because of slight differences in the sides of the car?  Or is it a crapshoot?
1958 Sedan de Ville
Past:
1956 Fleetwood 75 Sedan
1957 Fleetwood 60 Special
1960 Coupe de Ville
1966 De Ville Convertible
1970 De Ville Convertible
1971 Eldorado Convertible
1979 Sedan de Ville
1980 Seville
Clewisiii
My 61 Fleetwood had a shim on the right front to compensate for the weight of the Air conditioning option.
wbdeford
Quote from: Clewisiii on July 29, 2020, 08:59:01 PM
I totally didn't think of that!  My car is an A/C car, so that is most likely the answer.  Thanks!
1958 Sedan de Ville
Past:
1960 Coupe de Ville
1979 Sedan de Ville
1980 Seville
