I am having a tough time getting my new vacuum advance installed on my distributor, which is all completely stock. It has a hard line/tube connecting to the vacuum advance unit, which makes it very difficult to get the nut started on the advance. Now I can't get the little tiny screws to start, which hold the advance to the side of the distributor. If I remove the vacuum line to the advance and install the screws holding advance onto the distributor, I can't get the metal line to start into the advance unit. I have tried bending the metal line, but can't seem to get it perfectly lined up. Does anyone know of some old surefire trick to get all of this to line up. I have not removed the distributor from the car to install the advance unit, because I know I will still have the same problem getting the metal advance line nut to start on the unit itself.
Thank you
Jim Greene
