Interior firewall panel in a '47 60S.
Started by bobrich47, October 21, 2020, 01:30:21 PM
bobrich47
I am going to replace the interior firewall panel in my '47. I have a sheet of 1/8" ABS that i will use. I need to replicate the hump in it & was going to use a heat gun to soften it, then press it down on the old one. Has anybody else made one of these, or something similar?  I also need to replace the insulation behind it. Any suggestions on materials for heat shield/ insulation  and sound deadening?  Dynamat or something better?  Thanks
Bob Richards
Jeff Hansen
Jeff Hansen
1941 6019S Sixty Special
1942 7533 Imperial Sedan
Is the old one metal or plastic?   Not real sure what you're trying to do here, cover or replace the original?   Why?
A plastic shop maybe the place to go, they can vacuum form or have a better method / material.
If metal, just repair/replace.
Brad Ipsen CLC #737
Brad Ipsen
1940 Cadillac 60S
1938 Cadillac 9039
1940 Cadillac 6267
1940 LaSalle 5227
1949 Cadillac 6237X
1940 Cadillac 60S Limo
