MikeIf it cools sufficiently at higher speeds then the condenser is not clogged internally or at leastThat doesn’t seem to be the reason for poor cooling at low speeds. If your radiator fan(s) are working AND there is sufficient oil in the system AND the expansion device is correct and unclogged you might have bad or failing valves in the compressor. The reason to recharge by weight to factory specs is that then you cAn use the diagnosis matrix in the FSM. I have never known them to fail
MikeYou have a lot of electronics tied int your control system. If this were me I would bite the bullet and get the FSM and diagnose the individual systems before you start chasing your tail blindly. Again that is what I would do. Greg Surfas
