1937 lasalle door hinge pins
Started by Dexfoster, November 21, 2020, 07:49:58 PM
Dexfoster
Anyone know what size door hinge pins fit a 1937 lasalle coupe? Who sell them or i could just get a set and cut them to length. Any info is appreciated thanks!
Dex
1947 sedanette
1947 sedan
1946 sedan
1957 coupe deville
harvey b
When i needed some for my 37,i just went to my bodyshop supplier,they have a large box of universal pins and bushings,i found a pair that looked like the right size,got bushings with them,drilled out the part that stays on the car for them,then pushed the pins into the other part,was easy to do.I do have my own bodyshop,this was the type of thing i do all the time 8).It is not that bad,just be careful removing the old pins,the hinges are not real strong,the little "ears" can snap off.Look on youtube,should be someone on there doing it.the new pins are likely too long,they cut easy with a die grinder. Harveyb
Harvey Bowness
Dexfoster
Harvey B
Thank you sir! I was just looking to order a set if someone knew a size. Plus side, it just has random bolts in them right now. I will pull a door and run by a body shop.
Thanks again!
Dex
1947 sedanette
1947 sedan
1946 sedan
1957 coupe deville
