Quick spring question
Started by 60eldo, November 26, 2020, 02:04:20 PM
60eldo
   So if I removed all 4 springs on my 59, would the car still roll? So I can move it.
Jon. Kluczynski
Cadman-iac
It should be able to roll even without the springs,  as it would be sitting on the bump stops. If those are not there or are damaged or collapsed, then you may have an issue.  But what I did to the front of mine is just put a metal rod in place of the springs and it holds the car up.
Rick
CLC# 32373
