I have pin holes in the back plate of the water pump.
Started by Mike Baillargeon #15848, December 04, 2020, 05:30:43 PM
Just got the water pump rebuilt and Arthur Gould Rebuilders said the back plate needs some pin holes addressed.
The rebuilder told me that they were afraid to put the welder on it to plug those holes.....he said maybe try JB Weld....??
These holes are right on the edge of the raised portion of the stamping...there are about 6-7 pin holes....
Unfortunately the pump is a one off and there are none anywhere to be found.....1934 LaSalle.....an Oldsmobile built straight 8....
What's the best way to fix this...weld....braze....JB weld...???
see my pictures below....
By the way, Gould charged me $200 with a 3 week turn around...
Baillargeon
#15848
Oh dear, what a mess, and you are lucky it was caught before loosing all its cool(ant)
There are a couple of ways around this, and one I would suggest is having a radiator shop completely clean it, and let the operator fill the holes with solder.
A job that is well done should never leak, but I have to restate, it needs to be a good job.
It could be welded up, but that would lead to a lot of distortion, but a task that I would only attempt with the Oxy Welding process.
One has to remember that there is a lot of hydraulic forces in this area, as the water is moved around by the impeller.
Another method would be to replicate the cover, but using a flat piece of steel, with a spacer made to cover the distance of the step, if there is room.
Bobby B
I do have a stupid question, and that is what was the point of rebuilding that pump without first repairing the damage before returning it to you or at least bring it to your attention as the how you would like to proceed.
                                                     Bobby
1968 Mustang Convertible
1973 Mustang Convertible
1969 Jaguar E-Type Roadster
1971 Datsun 240Z
1979 H-D FLH
Quote from: Bobby B on December 04, 2020, 07:03:46 PM
                                                     Bobby
Good question Bobby.
He did call me and asked if I wanted him to take a shot at the JB weld fix...that was after the rebuild though...
I think he knew this is a hard to find pump, so he went ahead and rebuilt it.....And I'll tell you it wasn't leaking when I sent it to him....but it must have been on it's way to leaking and the sandblasting just pushed it along....
I got no choice, I have to fix this one.
Baillargeon
#15848
Is the JB Weld not the way to go??
That would be easiest.....
Baillargeon
#15848
chrisntam
I really can't help with the question of JB Weld or not, but what about searching out someone who could make a replacement plate for you?  That's be the best long term solution.  While it's being made, JBW it up and run it until it leaks, then put the replacement plate on.
Somebody in this country of ours has to have the capability to make that.  I don't know who though.
The only other option is pucky it up, refill with antifreeze and quick sell the car!   ;)
1970 Deville Convertible
Dallas, Texas
KenZ
Bobby B
Quote from: chrisntam on December 04, 2020, 08:21:28 PM
There's nothing difficult about making that part. Any good fabricator/ machinist with the proper equipment can reproduce that. It's not full of complex bends or angles. Once they make the die, it would just get pressed out. The key would be the cost factor, but if you find someone retired that's up for the challenge, let them have a crack at it. If it's steel, why couldn't the holes be brazed/welded closed? I find it hard to believe that they couldn't repair that, knowing the scarcity of the part.
                     Bobby
1971 Datsun 240Z
1979 H-D FLH
Tom Beaver
I would not use JB Weld if it were mine.  I would braze it up or use silver solder as Bruce suggested. Also machining out a plate wouldn't be that hard to do as well.  It's so corroded that fixing these holes may be just the beginning of your problem.  Brazing or soldering may be just a stop gap measure.
Tom Beaver
Mike Josephic CLC #3877
JB Weld, being an epoxy, will not hold up to
constant contact with water / glycol solution.
It will fail, especially since this solution is
heated.
How long would it last?  Impossible to say but
this is not a permanent repair.  Either solder
it up or as one poster suggested have a new piece
fabricated.  The latter would be my first choice.
1955 Cadillac Eldorado
1973 Cadillac Eldorado
1995 Cadillac Seville
2004 Escalade
2011 Buick Lucerne CX
CLCMRC Museum Benefactor #38
Jay Friedman
Why not just buy another pump--even one that is just good for parts--that has a good back plate and replace your current back plate with the new one.
You don't state what year Cadillac the pump is for, but there should be one on ebay or available from one of the many Cadillac parts vendors.  I'm only familiar with parts availability for my own 1949 Cad, for which water pumps and their parts are readily available.
1949 Cadillac 6107 Club Coupe
Decatur, Georgia
CLC # 3210, since 1984
Big Fins
Current:
Past and much missed:
1977 Brougham de Elegance
1972 Fleetwood Brougham
1971 Sedan de Ville
1970 de Ville Convertible
1969 Fleetwood Brougham
1969 Sedan de Ville
1959 Sedan deVille
Quentin Hall
#12
Don’t use jb. Send it to me. I’ll weld it up with a mig on the major holes and silver solder the rest. You cover postage and I’ll do it for free.
53 Eldo #319
53 Eldo #412.
53 Eldo #433
57 Biarritz
53 series 62 conv
39 Sixty Special Custom
57 Biarritz
Quote from: Quentin Hall on December 05, 2020, 03:24:02 AM
Quentin that's a very generous offer and I thank you!! I might take you up on that but I'm going to try and figure this out here.
From what I understand Cadillac had Oldsmobile build the motors for the 34-35 LaSalle's to a Cadillac spec. The 34 water pump is a 1 year only pump....I've been looking for a year for another pump to have as a spare with no luck....
I'm leaning toward making a new plate and then welding on a dome/cap in the center of that plate to clear the impeller axle....that cap will have to be shallow like the original so the pump can still be bolted to the head/block...
Where am I going to find that dome/cap?
Baillargeon
#15848
savemy67
Hello Mike,
I agree with the others that a newly fabricated plate may be the best choice in the long run.  The photos indicate the next pinhole is one driving tour away - extensive pitting of the inside of the cover plate.  Someone like Pete Sanders could fabricate a plate from steel, but I don't know if he has a press of sufficient tonnage to stamp steel of the same thickness as the original plate.
You may want to consider using stainless steel shim stock.  You can get a small piece (one square foot) for less than $20.  Shim stock is available in varying thicknesses - from a few thousandths of an inch to a few hundredths of an inch.  I would use a thin piece of shim stock to fabricate a "liner" for your corroded plate.  The liner needs to be thin enough so that it does not interfere with the impeller, nor cause the back of the plate to hit the block.  Using a liner allows you to keep the original plate in place.  This might be doable by hand.
I suggest stainless because of its anti corrosion properties.  You could go to sheet metal supplier and get a piece of sheet metal of sufficient thickness to make a new plate, but non-stainless steel will corrode sooner.
Respectfully submitted,
Christopher Winter
Christopher Winter
1967 Sedan DeVille hardtop
I agree with the one tour away leak scenario.   That's severely pitted, not just at the holes.   The base metal is porous and corroded anywhere it's black spots.   Soon as it sees a weld temp, it'll melt, ball up, and burn.   I had a thermostat neck like this and it was not repairable.   Had to use new metal.
I think one could easily be made from the proper gauge sheet metal.  (Who's going to see it back of the water pump?)   Cut out the bolt flange with the center hole from a flat piece of sheet metal.  I'd normally reuse the original flange but it's too far gone.   Cut an oversize disk of sheet metal and roll the edges to fit the hole.  Weld the seam shut water tight.   Has to be done properly to avoid warping, but I'd make that part by this method.   It's probably 11 ga of so plenty of beef.
This comes from stamping and not properly cleaning the surface of contaminates smashed in.   I had a modern diff cover do this which is much milder service, and when I bought a replacement from the factory it was almost in the same shape sitting off the shelf.   I had to blast and epoxy paint just to use it.
harry s
Pete Sanders has done several pieces for me always to my satisfaction. Harry
Harry Scott 4195
1941 6733
1948 6267X
2011 DTS Platinum
Quentin Hall
How about you start with a piece of Stainless plate the thickness of the stamped plate, looks about 1/2 inch. Machine out the middle and countersink the retaining bolt holes and use Allen head bolts . So long as the bolts don’t interfere with whatever is behind.
53 Eldo #319
53 Eldo #412.
53 Eldo #433
57 Biarritz
53 series 62 conv
57 Biarritz
Does it have to have the dome?   Or could the 'dome' be machined into say a 1/2 thick piece of steel or aluminum?  Just longer bolts to reach through the now much thicker cover?     I was also thinking the plate could be flat then you make basically a thick gasket spacer sort of thing.   Further thinking about that if you could make the spacer you could also likely make the thick 1 piece version.
There are all kinds of hobby level CNC machines available out there now that were designed for wood but people have found with the correct bits and some programming skills they can do metals.  I have seen people make working gears with them so something like this I think would be fairly easy.  I don't have one or know anyone with one so I can't help but I would think there would have to be someone out there.
Ralph Messina CLC 4937
Hi Mike,
Have you considered 3D printing in a metal or high performance plastic?
2018 GMC Yukon
