I replaced my fuel pump on my 78 Biarritz.
It was easy and straight forward.
One additional thing.
There is a section of the Cadillac shop manual regarding suspected fuel delivery
issues you have.
It states that while you have the fuel line from tank disconnected, that you carefully set your air compressor
output to 5-8 lbs. of pressure , attach a blow gun, and gently back blow the line to the tank until your
hear bubbling and gurgling. This is meant to gently blow away any collected debris from the mesh pick up sock in the tank.
Hope this helps.
