V16 Clutch installation
Started by Jeff Trahan, January 12, 2021, 09:16:50 PM
Jeff Trahan
Does anyone know an easy way to re-install the clutch in a 1938-40 V16 without the aligning tool J-1031? Alternatively, is there anyone who can lend me aligning tool J-1031? Thanks.
Jeff Trahan
#28564
1938 Cadillac V16 9033
1947 Cadillac 62 Convertible Coupe
1958 Cadillac Biarritz
Brad Ipsen CLC #737
V-16 is not unique here.  The spline is the same as the V-8.  I just made one from a trans input shaft. If you can't find something local with this info I can supply you a trans input shaft.  Looks of junk trans out there.
Brad Ipsen
1940 Cadillac 60S
1938 Cadillac 9039
1940 Cadillac 6267
1940 LaSalle 5227
1949 Cadillac 6237X
1940 Cadillac 60S Limo
Make one out of a piece of timber, and put it in a lathe and machine the diameters of the Pilot bearing, and the ID of the Clutch spline, and you are set.
You have all the measurements you need on your transmission input shaft.
Jim Stamper
    I made one from the handle of a broken pool cue a few years ago on a lathe. It worked fine.  Jim Stamper CLC#13470
Jay Friedman
I made one on a lathe from a piece of an old broom stick.
1949 Cadillac 6107 Club Coupe
Decatur, Georgia
CLC # 3210, since 1984
I have even seen where a person got a piece f dowel, the same diameter as the Pilot Bush/bearing, and wrapped the piece with tape to increase the diameter.
I even once used a 1/2" Socket Extension and that fitted the pilot, and then just juggled the clutch spline so it was the same gap all the way around.
Meaning, no need to buy a special tool.
Jeff Trahan
Thanks. I'll give it a try this weekend.
Jeff Trahan
#28564
