You're talking about the era when GM accountants embraced plastic over traditional materials. It really was a big change.OTOH, the plastics that were used early on were high quality (for plastics). I don't worry about disassembly of anything on my '74. My '94 Corvette? Anything I touch will have to be replaced. In comparison, the plastic components on a 90s Mazda Miata last forever (just like the earlier GM stuff). Bean counters can do a lot of harm.The worst is probably 90s German, which is full of plastics and wiring which are intentionally designed to bio-degrade. Greens are worse than bean counters.
It is also hard to say reliability when the 60s cars came with a 30 day warranty. The entire front end of my 61. Fenders inner fenders hood grills, mount to only the firewall. And one central body mount under the radiator core support. I have heard people argue that with the x frame the A pillar would crack at the room line. I did see a lead joint on my car crack there. I see a lot of people try to hunt down rear window leaks that could be from old seals or body flex.
Built "better". No. Really it only had different styling and features. If your talking 50s and 60s and base coupes and devilles they had the same construction as anyone else. All vinyl and fabric seats zig zag springs for support. The door and trim panels were cardboard big fit and finish gaps everywhere and the stitching was not straight. When you went to Fleetwood or eldorado you got pocketed coil spring seats. And started getting leather. What set Cadillac apart was styling. Which is subjective. And what features came standard. But Cadillac often was not the first with those features. GM regularly used Oldsmobile as a test vehicle for a new feature. After it was proven they would make it an option or standard equipment on Cadillac.
You should read up on things. Cadillac engines hade more than twice the nickel content as the "best" chev engine. back thenThe grilles, Cadillac grilles were op to 20 or more pieces of extruded aluminum fitted together, whereas chev and most other grilles were a one piece very thin stamped aluminum construction. Sound isolation: Cadillac made extensive use of sound and vibration isolation materials in the body and suspension that others simply did not have.Suspension. Chrysler (and imperials) used bone jarring leaf springs well into the 70 and 80s. I'm not sure when lincoln went to coil springs but Cadillac was out in front of this. DeVilles had leather / cloth and all leather seating in the 60s and onward. The DeVille Convertibles had all leather seats as standard equipment.
