Overdrive for early '30s torque tube drive shift
Started by Rob Bogan, January 25, 2021, 08:17:39 AM
Rob Bogan
I'm considering a overdrive for my '31 LaSalle.  There was a discussion 6 years ago about this.  Looked straight forward.  Couldn't contact those guys.  Anybody out there with experience and info????
Thanks.
phildeville@cox.net
Give these guys a call. I have seen their work on a '30 Cadillac & '29 LaSalle. It won't be cheap!
GEAR VENDORS, INC. 1717 North Magnolia Avenue, El Cajon, CA 92020
Toll Free 800-999-9555 • Telephone (619) 562-0060 • Fax (619) 562-1186
Phil
Phil Terry  CLC# 15270
Mike Baillargeon #15848
Quote from: Rob Bogan on January 25, 2021, 08:17:39 AM
Thanks.
Robert, as you go thru that process can you keep us posted....the good the bad and the not so good...
The overdrive and power steering conversions are of interest....
Baillargeon
#15848
Rob Bogan
Rob Bogan
Phil,
Thanks.  Heard about them.  Any guesstamate about the cost?
Rob
Omarine
Im interested too. I can tell you the stand alone gear splitter is almost $3k. Then labor and shorten drive shaft. I remeber something about 6 volt vs 12 volt...
1949 Harley Davidson FL
1952 Cadillac Coupe de Ville
1961 Chevy Impala 2 dr hardtop
Rob Bogan
Oscar,
Haven't called them yet.  But the $3k is probably a little low.  Big thing will be finding someone who can to the modification.  6V or 12V is not problem.  Waiting for the right time to spring project on the Mrs. LOL
I'll keep everyone posted.
Rob
jackworstell
We put a Borg Warner OD in our 1937 Buick series 40 which has a torque tube.
We are happy with the results
I think it might have these advantages over a GearVendor
    Reduces RPM by 30%  ...better than the GearVendor
    Keep system at 6V if you want or go to 12V  ( for actuating the solenoid )
    Free-wheeling feature below about   28mph
I'm a little hazy on these three points but I believe them to be accurate
Solenoids for the BW units are available in either 6V or 12V
BUT...the fellow who did the conversions....Lloyd Young  who lived in a town not far
from Columbus Ohio...is no longer with us.   I understand that a fellow
from about the same area has taken over the business...but for now
I can't find his name/address
In our instance we removed the  entire "pig"/torgue tube assembly and took it up to Lloyd
and then picked it up a couple weeks later.  We did the install ourselves
All  told about $2000.   Money well spent
Jack Worstell   jlwmaster@aol.com
jackworstell
About adding power steering....we did it for both our 1937 Buick and our 1937 Cadillac
Worked out pretty good....but not an easy thing to do
We used electric power steering units out of Equinox/Saturn cars ( used units )
Jack Worstell
Quote from: jackworstell on January 27, 2021, 08:27:32 AM
Jack Worstell
Jack, how did you handle the 6 volt car to the 12 volt Saturn steering?
That whole electric setup is all tucked under the dash right?
Baillargeon
#15848
jackworstell
Mike.....we separated the EPS into the two major components
             EPS ECM   went under the dash
             EPS   motor unit when in the engine compoartment
We did this because (a)   space in the engine compartment was limited  and (b)
we didn't want to put the ECM part in a hot environment
It is tedious to separate the two  components.....four short ( about 4")
small gauge ( 22 gauge ?)   have to be separated and
extended by maybe 20"
For 12V   we put a tractor battery in the engine compartment on the other side
from the EPS motor unit.   We keep it charged with one of those small converters
.....it only puts out maybe 5 amps   This is enough because even though
the ESP can pull as 40 amps briefly....the overall average current draw is
surprisingly low.
Jack
Baillargeon
#15848
