1955 Cadillac rubber intake duct
Started by Cadillac Jack 82, February 24, 2021, 12:35:02 PM
Cadillac Jack 82
Does anyone make these or am I SOL?  I was inspecting mine and its turned rock hard over the years.  I'm afraid when I go to service my AC that something will break.
Tim
CLC Member #30850
1959 Cadillac CDV "Shelley"
1964 Cadillac SDV "Rosalie"
Past Cars
1937 LaSalle Cpe
1940 Chevrolet Cpe
1941 Ford 11Y
1954 Buick 48D
1955 Cadillac CDV
1955 Packard Clipper
1957 Cadillac Series 62
1962 VW Bug
1962 Dodge 880
1966 Mercury Montclair
1968 Chevy Chevelle SS
1968 Plymouth Barracuda
1977 Lincoln MKV
J. Gomez
Quote from: 55 CDV Fan 82 on February 24, 2021, 12:35:02 PM
Tim,
If you are referring to the rubber A/C flex line for the air exhaust on both sides of the evaporator I’m not aware that anyone is making these, and if you are lucky in finding them in eBay they usually got for two arms and three legs.
Good luck..!
J. Gomez
CLC #23082
Cadillac Jack 82
Its the square looking rubber boot that comes off the blower motor.  So I guess I'm SOL?  Mine are there and they look intact but they're rock solid.
Tim
CLC Member #30850
Past Cars
1937 LaSalle Cpe
1940 Chevrolet Cpe
1941 Ford 11Y
1954 Buick 48D
1955 Cadillac CDV
1962 VW Bug
1962 Dodge 880
1977 Lincoln MKV
J. Gomez
Quote from: 55 CDV Fan 82 on February 24, 2021, 03:14:00 PM
Tim,
I was told by an old mechanic that he use to soak the old rubber pieces in vinegar to soft them up, now I’ve never try that trick so can’t testified if that is legit.   ???
Good luck..!
J. Gomez
CLC #23082
G Pennington
IF you can get them off without damaging them,  try soaking them with silicone spray and sealing in an airtight bag.  Let soak for several days, repeat as necessary.  I was able to rejuvenate several items on my '53 this way.
Gary Pennington
   1953 6267X Convertible
   1941 6267D Convertible (2 door)
Cadillac Jack 82
Tbh I'm afraid to remove them.  The original rubberized coating on the motor casings still exists but its brittle as all get out.  I suspect the rubber boots would crumble if I did that.
Tim
CLC Member #30850
Past Cars
1937 LaSalle Cpe
1940 Chevrolet Cpe
1941 Ford 11Y
1954 Buick 48D
1955 Cadillac CDV
1962 VW Bug
1962 Dodge 880
1977 Lincoln MKV
