All TH400 output shafts have the same spline size, but in early years I have seen some with a smaller yoke outer diameter. The yoke of course is matched to the seal, output bushing, and trans tail cover. If some of the smaller dia parts went not available, you could change out the above set and convert to the larger size, I have done that to standardize everything here. It can be done without removing the trans from the car, but of course a different yoke is used and tail housing. A bad bushing would tend to take out the seal before long. Bruce Roe
All TH400 output shafts have the same spline size, but in early years I have seen some with a smaller yoke outer diameter. The yoke of course is matched to the seal, output bushing, and trans tail cover. Bruce Roe
This does not sound right to me. Are you sure it is a TH400, with a vacuum modulator? The later yokes were all about 1.89 in dia, and I am pretty sure the early small ones were about 0.2 smaller, 1.69 in. 1.58 in is not right. Bruce Roe
Ha Ha, I must convert from Metric! Thanks for the pictures. The 47.95 mm is the 1.89 in I mentioned, the 43.2 mm is the smaller 1.70 in, a little more accurate than my 1.69 in memory. Both of these are not 1.58 in, just where does that come from? In every case the size of the splines on the output shaft is the same. I do not know what choices Cadillac made in 1966, but either diameter yoke has been used in either short or long tail extension housings. For either length, it is possible to change to the other dia yoke by changing the extension housing with its different dia seal and bushing, without removing the trans from the car. There were 4 in, 9 in, and 13 in tail extension housings, but that is not the problem here. It is necessary to completely dis assemble the trans to change the shaft to a different length. There is also the difference of yokes that just slide over the splines, and yokes which have a long unsplined outer tube that extends farther in, to seal on an O ring on the output shaft. These yokes have a center air vent. If used on a shaft without the O ring, oil will come out the vent. The short yoke has no vent, and will work with either style shaft. Bruce Roe
Hello Scott,When I rebuilt my '67 TH400, it had two bushings in the extension housing. The rebuild kit I got from Fatsco had one bushing, so I ordered a second. The attached photos show the new bushings (wider/longer) along side the old, original bushings, as well as the fit of the new bushings on the driveshaft yoke.If your measurements are correct, .100" difference is way too much clearance between the OD of the yoke and ID of the bushing. The bushing(s) will "crush" a little upon installation, but no where near .100".In my case, the bushings fit fine over the yoke before installation, with a few thousandths clearance (approx .004"). When the bushings were installed in the extension housing, the yoke would barely rotate, so I honed the ID of the bushings until I was satisfied with the fit.As Bruce Roe and Roger mentioned, .100" is too much clearance, and is likely to lead to premature failure of the seal. Transmission bushings should have less than .010" clearance as they function to hold rotating shafts in alignment. As Bruce Reynolds mentioned, Cadillacs had a unique extension housing in their Hydra-Matics for many years. Is it possible your car is not fully original?Respectfully submitted,Christopher Winter
I just replaced the bushings, clutches, and seals in my 64's TH400 a few months back. Mine took the 5105-L tailshaft bushing from Fatsco. The original was worn to the point that I could rattle the driveshaft inside of that bushing. This was just holding the tailshaft extension over the driveshaft yoke, and no oil seal installed. With the new bushing, you couldn't feel play at all, but rotation in the bushing was nice and smooth. My seal was so bad that if you jacked up the front of the car, trans fluid would just pour out the back. The ultimate cause was that the driveshaft bearing was shot. Car has not been run yet - it is still apart.Be aware that GM staked that bushing in. You will see the ID dimpled in in two opposing locations. It's a little bit of a pain to get out, but it'll go.
IIRC, a 64 is an x-frame with a center carrier bushing, for a two piece driveshaft, correct? So this might not be relevant at all, but what symptoms did you have driving it? Any harmonic vibration or noise?
