Hi Laurie -- glad you're having fun with the Ark.That's what this hobby is all about after all.Mike
Laurie, Have a pressure washer of your own I presume? Why not pick up an undercarriage wash attachment? There are several styles to choose from. Some can be moved around to clean the driveway too. https://bestcarcleaningproducts.com/automotive/best-pressure-washer-water-broom-undercarriage-cleaner/
Laurie,We need a photo of you, and your pit crew with the Ark. By the way, I'm a great fan of Cape Cod. Stream WFCC, FM up here in Maine (107.5 on the Ark's radio) every day -- broadcasts from Chatham (their adverts are regionally unique, such as "Zoe and Company Bra Fitters in Hyannis", the Cape Cod Gutter Monkeys, etc) yes, Old Cape Cod still exists ... Happy day to you Laurie, James
I'm confused. Driveshafts don't leak. The rear seal on the tranny or the pinion seal on the differential can leak.?? Is Michael fixing one of the other two and you are rebuilding the driveshaft just "because"? (Not a bad idea and not terribly expensive)Yes, I've committed the cardinal sin of questioning your Gods. Sorry. Flame away!Glad you're having fun with the ark though . . . .
Laurie, did you have your carbie rebuilt? If not then the accelerator pump is not new. And unless your transmission was overhauled, its internal pumps are also not new. I'm glad you are getting out and about in the Ark.
I see you have the Fleetwood fender skirt trim pieces on. Nice.
The Ark may be dirty down under, but SISS you need a dirty boy in your life.BUTCHMAN
