47 60S interior questions
Started by bobrich47, April 01, 2021, 05:24:48 PM
bobrich47
Hello, I'm replacing the interior (headliner, carpet & seat upholstery)  and I'm having a couple issues.  First, the back cushion of the front seat. According to the body manual I have, it states to "straighten out metal retaining tabs of seat frame at bottom of seat back as shown  at "A".  I cant find or feel any behind the cushion. When I try to lift it up and out, It moves a bit & I can feel it's hooked somewhere.  So, I was going to just look from the back when I remove the upholstery on the divider.  Well that's my second issue. I'm not sure how to remove the Robe Cord. The example in the manual is not the same type. I think its Buick or Olds, so it's no help.    I removed the phillips screw on the underside  of the end bracket but, it dosent come off.  Do i need to drive a pin out through that small hole?    This body manual I have is very limited to Cadillac applications. Is there a Fleetwood or one more Cadillac specific.     Thanks, Bob.
Bob Richards
bobrich47
I tried to post more photos but only 1 went through. I'll try again.
Bob Richards
bobrich47
Not sure why they flipped. The 5th photo down is the under side of the robe cord.
Bob Richards
