Author Topic: A5 Compressor question  (Read 418 times)
Offline 55 CDV Fan 82
  • CLC Number: 30850
  • Name: Tim Neumann
« on: April 02, 2021, 01:23:11 AM »
So my AC works but the compressor seems hot to the touch.  Is this normal or a sign of it going bad?  It doesnt make noise and seems to work appropriately.
Tim
CLC Member #30850
1955 Cadillac Coupe Deville "Evelyn"
1967 Buick Wildcat Convertible "Joyce"
Past Cars
1937 LaSalle Opera Coupe "Adeline"
1940 Chevrolet Coupe "Scarlett"
1941 Ford 11Y truck
1954 Buick Special 48D
1955 Packard Clipper Super Panama
1957 Cadillac Series 62 Coupe
1962 VW Bug
1962 Dodge 880
1966 Mercury Montclair
1968 Chevrolet Chevelle SS
1968 Plymouth Barracuda
1977 Lincoln
Offline J. Gomez
  • CLC Number: 23082
  • Name: J. Gomez
Re: A5 Compressor question
« Reply #1 on: April 02, 2021, 08:40:50 AM »
Tim,
First question is; do you have the correct oil viscosity added to the compressor, and second have you added the correct amount?
These compressors with R12 required the mineral oil viscosity of 525 with about 9oz added to a new drained setup.
J. Gomez
CLC #23082
Offline Cadman-iac
  • CLC Number: 32373
  • Name: Richard Cook
« Reply #2 on: April 02, 2021, 09:58:05 AM »
Tim,
  Most of the compressor will be hot to the touch, that's normal as it's compressing the refrigerant, and heat is the result. The only place that is not hot is typically right at the low side hose connection.
 Now if it's making an excessive amount of noise, and the paint is baking off, those would be signs of a problem.
 Rick
  • CLC Number: 30850
  • Name: Tim Neumann
« Reply #3 on: April 02, 2021, 04:33:01 PM »
Rick its quiet but just hot to the touch except for one of the lines which is ice cold.  Guess its working? Lol.  I'm not familiar with these old systems.  It kept me cool today and its 96 degrees.
Tim
CLC Member #30850
Past Cars
1941 Ford 11Y truck
1962 VW Bug
1962 Dodge 880
1977 Lincoln
Offline Cadman-iac
  • CLC Number: 32373
« Reply #4 on: April 04, 2021, 02:43:31 AM »
Sounds like it's working just fine then.
