'94 Fleetwood On-Board Diagnostics
Started by fellenzer, May 30, 2021, 12:10:19 PM
fellenzer
Anyone know if the on-board diagnostic system will display things like coolant and transmission temperatures? Thanks.
Michael Fellenzer, #30007
Indianapolis, IN
1976 Eldorado Convertible
1976 Fleetwood Sixty Special Brougham (EFI, ACRS)
1976 Coupe deVille (Astro/Cabriolet)
1984 Seville
1989 Fleetwood Coupe
1989 Sedan deVille
1992 Fleetwood
1992 Coupe deVille
1992 Sedan deVille
1993 Sixty Special (Ultra)
1994 Fleetwood Brougham
2015 SRX
I don't think so.  94 may not have had an electronic transmission so may not be any sensors in it.
Engine temp should be available,  not trans temp.
fellenzer
I have the '94 service manual and can find all the stuff about checking codes and diagnosis but I can't find any of the information about running diagnostics while driving the car like some of the other models have. Any clue where to find it?
Indianapolis, IN
1984 Seville
1989 Sedan deVille
1992 Fleetwood
1992 Coupe deVille
1992 Sedan deVille
2015 SRX
TMoore - NTCLC
Yes, both engine coolant temperature and tach rpm (first two digits only) are available via the Climate Control diagnostics:
00 - ECM faults
01 - CCM faults
02 - ACAC faults
03 - SIR faults
04 - ABS/TC faults
05 - program #
06 - engine RPM
12 - vehicle speed
16 - sun load sensor
17 - current temp valve position
19 - temp valve position (hot)
20 - temp valve position (cold)
24 - engine coolant temp
22 - commanded temperature valve position
25 - in vehicle sensor
28 - ambient sensor
30 - ignition cycles
fellenzer
Thanks. I'll be anxious to check that out when I get the car back (just loaned it to a friend who's own car is in the shop).
Indianapolis, IN
1984 Seville
1989 Sedan deVille
1992 Fleetwood
1992 Coupe deVille
1992 Sedan deVille
2015 SRX
fellenzer
I'm looking in this dang book and I cannot find that list. LOL.
Is trans temp there anywhere?
Indianapolis, IN
1984 Seville
1989 Sedan deVille
1992 Fleetwood
1992 Coupe deVille
1992 Sedan deVille
2015 SRX
