Installing parade boot 76 Eldo
Started by 1776-1976-Eldo, June 23, 2021, 07:37:30 PM
1776-1976-Eldo
How low should the top go without pushing to allow the hard parade boot to install? I have not tried yet, but the top seems pretty high and don't want to push enough to break the window. What is the best practice?
1976 Bicentennial Eldorado #198 Dallas, TX
With my /72, which isd virtually the same as the '76, the top goes down deep into the well, but a slight bit of one side of the canvas sits up a fraction, but that is easily "bent over" for the use of a better word, and everything fits.   There should be no pressure required to "flatten" the top when folded.
1776-1976-Eldo
Mine is stopping much earlier than that.
Have you got a picture?
The glass folds down under the roof material, and is fully out of the way, unless you have something in there stopping it, but if that was being stopped from fully retracting, then there is every possibility that it could break, which you definitely don't want that to happen.
1776-1976-Eldo
here is a pic about where it stops.
John,
Definitely too high.
But, when you are lowering it, have someone you can trust to operate the switch, and by that, I mean, someone who will stop when you tell them to, so that you can be back there, looking at what might be getting caught.
Could be anything, like some material getting caught in the folding mechanism, or some other "simple" explanation.   Look at the side padding, the headliner, and if there is any stretching which may stop the arms dropping.
Any chance of some pictures of it up close?
KOKNEYELDO
I have a 75' Eldo convertible and your top should go all the way back with no assistance.
Check the cables.
If glass, do not apply any pressure to it.
Present cars:
1975 Cadillac Eldorado convertible
1957 Ford Thunderbird
2007 Jeep Commander Overland
2018 Audi A3
Come On You Blues!
MaR
Quote from: 1776-1976-Eldo on June 23, 2021, 10:30:53 PM
The guide arms are out of adjustment. They are the arms that push the main folding arms out when the top goes up. When they are out of adjustment, the top will have a hard time reaching the top of the windshield and when it folds up, it will not stack up properly in the well.
mrmatthew
My '76 did the same thing. Stuck up about 4 inches & no pushing down would budge it.The logical fix seemed adjustment... Researched online, Shop manual, couldn't find any instructions to try..No professional help in my area. Then Hurricane Harvey came along & I never had another problem with that car again.
You may be lucky enough to have someone in your area proficient with scissor tops & can fix your problem since the boot gives the car that neat finished look...BTW nice looking Bicentennial... What number ?
1776-1976-Eldo
Matti R
Quote from: MaR on June 25, 2021, 12:22:48 PM
Thanks for good info. How to adjust those?
Best regards,
Matti
CLC #33333
67 DeVille convertible Sudan beige
79 Seville
64 Sedan DeVille
66 Calais Coupe
Need to take unto a pro shop.
If you get it out of whack you will break the back window.
R Pope
Check you well liner. I bet it is to tonight and will not let the top rectract as far as it should. I have the same problem. I broke my rear window and had a shop redo the rear panel. Now the rear well liner is too tight and it does not go down far enough for the top to 'disappear'. Always planned on removing a bunch of staples or cutting it but just have not got around to it.
Big Fins
Also be sure there is nothing in the forward end of the trunk that could stop the top prematurely. Like the jack or part of it's assembly. There is 0 room for error here.
Mine also sticks up about an inch due to the way the canvas folds.
Current:
Past and much missed:
1977 Brougham de Elegance
1972 Fleetwood Brougham
1971 Sedan de Ville
1970 de Ville Convertible
1969 Fleetwood Brougham
1969 Sedan de Ville
1959 Sedan deVille
You also should take the tip back about 2/3 and fold in the canvas to help it stack better but if the top doesn't lower into the body low enough you won't get the hard or  soft boot on.
Matti R
Sorry but I do not get how to adjust guide arms. I don`t even know what they are because I am using Fisher scissor top manual and the parts have different names there.
Thanks in advance.
Best regards,
Matti
CLC #33333
79 Seville
64 Sedan DeVille
66 Calais Coupe
MaR
Quote from: Matti R on June 26, 2021, 08:40:19 AM
I really suggest that you get a service manual so you can see the diagrams. The process is to lower the top all the way, loosen the two guide arms at the pivot block and then make sure that the two large folding arms will now lay flat with no "springiness" in the folding arms. Problems with the rear glass have to do with the glass sliding arms that are in the well area and the 4th bow.
MaR
Quote from: Matti R on June 29, 2021, 04:59:16 PM
Thanks in advance.
Item #7.
Matti R
Quote from: MaR on July 01, 2021, 11:36:26 AM
Thanks. Actually, I have done that already.
Best regards,
Matti
CLC #33333
79 Seville
64 Sedan DeVille
66 Calais Coupe
