Front Suspension
Started by Jvteach07, July 06, 2021, 05:11:51 PM
Jvteach07
Can anyone help me identify these parts and if they are DIY or I need to bring it in to a shop for repair?
Thank you
Joe Tortora
1970 Cadillac Devill Convertible
Those are the lower ball joints.   It depends on your abilities.    I believe on that car those are held to the lower control arm with a thread on collar.   I'm sure there is a special tool to make unscrewing that easy but no idea how hard it is to improvise.     Its held to the knuckle like most with a tapered shaft that can also sometimes be tricky to get to pop loose.
I agree that not knowing what they are would suggest to me that replacing these joints is not a task that anyone without the know-how should attempt to undertake.
Yes, they could be classed as a DIY task, but then, anything apart from medical operations could be classed as DIY.
The Shop Manual will explain what has to be done, and the steps to take, but if you have to go out and purchase the necessary tools to safely complete the task, and you never use these tools again, then it would be cheaper to go to a Garage to get it done.
Tools needed at a minimum will be a jack, wheel wrench, pliers, Ring Spanner, large ball peen hammer, and an even larger one to act as an Anvil behind the upright when bashing with the smaller one.   Then, as I am not sure how the joint is held to the lower control arm, there could be a press required, or a drill and bits to remove rivets.
Complicated?   No, but strength involved, along with finesse, yes.
Cape Cod Fleetwood
Its going to a shop... that knows how to work on old cars.
They should have mentioned those ball joints when they did the stabilizer bars.
I'd take a look at the upper ball joints too.
And I'd be saving my pennies for new rotors.
I just had my entire front end done, including pittman arm. The only thing we
didn't change was the steering box. You'll only do this once, so....
I used all Moog parts, no problems.
The Past -
1996 Deville Concours
1981 Coupe De Ville (8-6-4)
1976 Sedan De Ville
1975 Sedan De Ville
If the lower arm is not supported during the ball joint's replacement, it will be very dangerous as the spring will push down the arm when the ball joint is removed.
From the way you asked about those parts, I'm concluding that it will be safer for you to let the work done by a shop.
klinebau
Quote from: TJ Hopland on July 06, 2021, 05:20:00 PM
This looks like a '70.  The lower ball joints are pressed in.  The lower control control arm will likely need to be removed in order to put them in a press.  For reference, the upper ball joints are also pressed in, but the factory added a tack weld to secure them.  Replacements are available that use a collar to secure them to the upper control arm.
1970 Cadillac Deville Convertible
Detroit, MI
