Door lock actuator
Started by Tpicks55, July 13, 2021, 07:05:13 PM
Tpicks55
Looking for a door lock actuator for a 75 Eldorado convertible drivers side.  Any recommendation would be helpful.  Thanks in advance.
75 Eldorado Convertible
94 Deville Concurs
2019 Lincoln Continental
2016 Cadillac XTS
Big Fins
Good luck. You'd be better off to take out the one you have and go through it. I've found passenger side actuators, but it seems the drivers side is near impossible to find. I just hate having to pull those door panel off more than needed.
Current:
Past and much missed:
1977 Brougham de Elegance
1972 Fleetwood Brougham
1971 Sedan de Ville
1970 de Ville Convertible
1969 Fleetwood Brougham
1969 Sedan de Ville
1959 Sedan deVille
pordy
honestjohn.com rebuilt the ones in my '73 devile (PO did it, I just found the receipt).
MaR
I have rebuilt them myself. It's about 50/50 on if they are even rebuildable. The issue is that where they are located in the door, rain water drips directly down on them and seizes them up solid once the rubber boot on top starts to degrade. In '78, they actuator was completely re-designed and I'm 90% sure it will bolt in but you will have to change the plug.
The later actuators fail too, but at least they are available and cheap,
same unit fits a lot of stuff.  Uses a 2 wire motor which must have
the polarity reversed to go the other way.  An actuator with different
wires for up and down would require a different switch arrangement.
Bruce Roe
Big Fins
And when they do seize up, that plunger is a real bear to try and get out.
I'll have to look into the later year parts. Changing out the plug is nothing, as long as the polarity is correct.
Current:
1971 Sedan de Ville
1969 Sedan de Ville
1959 Sedan deVille
Tpicks55
Thanks for all the replies.
94 Deville Concurs
2016 Cadillac XTS
I had to repair the actuator in my '72, and it was rusted stiff.
I finally got it apart, cleaned up, and when I put it back together, created a water seal using a piece of bicycle inner tube.
Tpicks55
Quote from: The Tassie Devil(le) on July 19, 2021, 09:17:19 PM
Thanks, I am doing the same thing, I hope I can save it as its really corroded.
94 Deville Concurs
2016 Cadillac XTS
MaR
Quote from: Tpicks55 on July 21, 2021, 09:20:04 AM
If you can get the internals of the seized up actuator out of the shell, you can put the internals from a four door actuator in the two door shell.
