1976 Cadillac Deville Generator Dash Light Still On?
Started by EAM 17806, August 07, 2021, 09:00:18 AM
EAM 17806
With two NEW alternators installed the dash light still comes on.  What's going on? All belts are properly installed and hookups are all okay.  EAM
Ev Marabian
1976 Cadillac Coupe DeVille, 1989 Chevrolet Caprice Classic, 1990 Pontiac Bonneville and 1996 Buick Skylark
Now days the new parts would be the most suspect but assuming they are not the issue I would be checking fuses.  Specifically one that should be labeled 'gauge/trans' which I think is a 10 amp.  If its blown and you replace it and it blows again I would be checking the wire that goes into the transmission just above the pan and its route to the side of the carb then the wiring around its switch on the side of the carb.
That circuit also runs the buzzer which among other things gets tangled up with the seat belts so that is another place for things to go wrong if at some point in the cars history someone did want to use the seat belts and didn't want to listen to the buzzer.   I have seen lots of poorly thought out and executed mods to that circuit cause issues later in the cars life.
EAM 17806
Quote from: EAM 17806 on August 07, 2021, 09:00:18 AM
Quote from: TJ Hopland on August 07, 2021, 10:20:28 AM
All the other gauge dash lights are working fine; wouldn't this generator light be out too if it were a fuse problem?  EAM
Ev Marabian
I would at least double check the 5A GAUGE fuse.  If OK, I would slap
in an alternator known to be good (previously tested).  And use a clamp
on to check alt output current, put on some loads (lights and blower).
Bad alternator diodes can light the GEN light, even with good or partial
output.  They can be checked with the alt apart.  Another cause is
weak wiring, causing a lot of voltage drop.  good luck, Bruce Roe
Its kinda a wacky circuit because when the alternator is spinning its basically sending 12v back to the bulb so it can back feed anything that is on the same fuse as the gen light which is most of the other indicator lights, gas gauge, buzzer, and the downshift circuit for the transmission.
You could unplug the small plug on the alternator and see if everything else still works.  Gen light should go out but the rest of the stuff should still work if the fuse is good.
That seat belt circuit is also a good way to pick up a lot of unexpected interactions because that buzzer ties into things like the door switches that work off ground so it only takes one thing to be out of place out of like a dozen things to cause all sorts of interactions.
1776-1976-Eldo
I will second checking the alternator. I had 2 that were bad for different reasons. It is very easy to take the alternator apart and ohm out the components. If 1 of the 3 legs on the diode trio is out, it will dim light the generator light. I was still getting good power out of the alternator even with a bad trio leg.
1976 Bicentennial Eldorado #198 Dallas, TX
EAM 17806
Quote from: 1776-1976-Eldo on August 08, 2021, 09:01:07 PM
It turned out the problem was the fan belt; it was on tight but needed to be replaced because it was slightly slipping because of too much wear.  I'm glad that's all it was!  EAM
Ev Marabian
Good news.
PS.  So, do you now have two new Alternators as spares?
EAM 17806
Quote from: The Tassie Devil(le) on August 08, 2021, 10:49:12 PM
Good news.
No, I had to return the ones in warranty to the parts store, rightfully so.  EAM
Ev Marabian
