Author Topic: 1941 Front Parking and Turn Signal Sleeve  (Read 308 times)
Offline J. Russo
  • CLC Number: 65003835
  • Name: JOHN P. RUSSO
« on: August 12, 2021, 08:59:35 AM »
Please see attached photos. Does anyone know if the bulb sockets/pigtails are still made for these original parts? I have 3 wire after market sockets that are in bad shape and would like to replace.
Thank you
Offline Tom Boehm
  • Name: Tom Boehm CLC #6750
Re: 1941 Front Parking and Turn Signal Sleeve
« Reply #1 on: August 13, 2021, 09:11:07 PM »
Did you try the places that make and sell wiring harnesses? Like Y & Z  or Rhode Island
Offline Daryl Chesterman
  • Name: Daryl Chesterman
« Reply #2 on: August 14, 2021, 01:51:08 AM »
Quote
I am not sure what you mean by this.  If you look at this web page from NAPA, is this what you need?
     https://www.napaonline.com/en/p/ECHLS6388
Or, do you need this?
     https://www.napaonline.com/en/p/ECHLS6251
Daryl Chesterman
Offline J. Russo
« Reply #3 on: August 14, 2021, 08:28:34 AM »
I added better views of the part as well as the illustration from the 1942 Cadillac master parts list I have. The illustration does not show the bulb wiring. I checked multiple websites including those that Tom mentioned and will call them Monday to see if they have something not on their site.
The part is two sided. One side is for a double contact bulb (1154) and the other side looks like it is for single contact. Looks like the part can be flipped based on the bulb type someone wants to use.
My current bulb sockets are after market 3 wire and need replaced. 1 wire each for the parking and turn signal, and one wire for ground. That's what I'm seeing on the wiring diagram also.
I'd like to replace my sockets with original and use this original part if I can. If not I'll just purchase another after market socket. I'm curious if anyone is using this part currently.
« Last Edit: August 14, 2021, 08:33:34 AM by J. Russo »
Offline harry s
  • Harry Scott 4195
« Reply #4 on: August 14, 2021, 10:49:16 AM »
John, The light socket is double sided as shown the one side is for a double contact bulb (park light & turn signal). The other side is for the two hot wires which attach the same way as the bulb by pushing and turning to lock. Your new wiring harness should have two wires for the connection. The ground is a body ground through the socket. I will look and see if I have a connection piece to get a picture of.      Harry
Harry Scott 4195
1941 6733
1948 6267X
2011 DTS Platinum
Offline J. Russo
« Reply #5 on: August 14, 2021, 11:10:38 AM »
Harry,
Yes. My new harness has wires for the parking light/turn signal bulb on both sides. I need the connection piece that the bulb and the wires connect to and that also fit this part on both sides.
Thank you
Offline harry s
  • Harry Scott 4195
« Reply #6 on: August 14, 2021, 03:48:18 PM »
John, Here's a picture of the plug that goes into the park,signal light socket. It has opposing pegs that are straight across from each other. The bulb goes in the other side with the staggered pegs. The small springs put tension on the bulb when it is in place. I'm not sure what your two wires on the harness look like. This is the only one I have. You might Marty Watkins, he has a lot of electrical connections.      Harry
Harry Scott 4195
1941 6733
1948 6267X
2011 DTS Platinum
Offline J. Russo
« Reply #7 on: August 14, 2021, 04:06:53 PM »
Thanks Harry,
I knew it had to be something unique. I'll check with Marty.
All Cads
