Quarter Panel Chrome Trim Removal Tips (76 Sedan Deville)
Started by JLanteigne75, August 17, 2021, 08:21:56 PM
JLanteigne75
Hi Guys,
I'm wondering if any of you could provide tips for removing these chrome trim pieces (see attached photos).  Is it as simple as getting a grip and pulling hard? Or is it supposed to slide in a certain direction?  I started with the pull method but did not want to continue and break something.
I'm finally getting around to repairing those eye-sore rust spots!
Jonathan
Jonny Lanteigne
1976 Sedan Deville Hardtop
jagbuxx #12944
The body side moldings and window belt moldings snap onto clips similar to these..the moldings on the doors also have a screw as well that is visible in the door jam. The moldings should pry off then go back on with a tap of a rubber mallet
Frank Burns #12944
76 Coupe d'Elegance EFI Galloway Green Firemist
70 deVille Convert San Mateo Red
61 Coupe Deville Bristol Blue
41 Series 61 Deluxe Coupe 6127D Black
08 STS 3.6 1SC  Thunder Gray
16 GTI Gray
03 T-Bird Black
16 Grand Cherokee Summit, Granite
19 Tiffin Phaeton 40AH
07 Corvette Blue
20 MB S450 White
"Whatever the occasion, there
is no better way to arrive than in a Cadillac.
Cadillac Fleetwood
#2
As a safety precaution, remove the trunk cardboard and look for any fasteners that are screwed to the body side. If memory serves, there are at least two, possibly more,  fasteners retained with speed-nuts  over the wheel opening and toward the aft end of the quarter, accessible through the trunk.  In fact, you will probably find threaded fasteners at the exact location of those rust spots! The remainder are plastic fasteners as shown, in either white or blue plastic.
Charles Fares
Forty-Five Years of Continuous Cadillac Ownership
1970 Fleetwood Brougham
1969 DeVille Convertible
1989 Fleetwood
"The splendor of the most special occasion is rivaled only by the pleasure of journeying there in a Cadillac"
jagbuxx #12944
Yes, good call Charles, on my 76 coupe, the molding on the front fender and end of the quarter molding were mechanically fastened.
Frank Burns #12944
16 GTI Gray
03 T-Bird Black
07 Corvette Blue
20 MB S450 White
60eldo
     Guys would the 1960 stainless come off similar, I have the same problem.
Jon. Kluczynski
G'day Jon,
Yes, there would be at least one mechanical fastening in these pieces, especially at the rear to fully retain it in place.
There may be more, bet the Shop Manual only talks about one, and the rest are clips.
But, as with anything that is old, and had a past life, previous repairers may have added extras.
