Fuel tank
Started by wendelltwmssr@aol.com, August 31, 2021, 04:08:27 PM
My 57 Brougham has 2 opening I am sure one is for the sending unit but not sure about the other one please share also can you tell me if the sending unit the same in a 57 Seville
Mike Baillargeon #15848
W, I'm going to guess the other hole is for the electric fuel pump...
Baillargeon
#15848
David King (kz78hy)
Brougham tank has 3 holes.  Fuel pump, fuel gauge sending unit, low fuel tale tale light sending unit.
Unique senders that are impossible to rebuild.  I made kit to use a modern sender that will work with the dash gauge and light the low fuel light just like the originals did.
David
David King
CLC 22014  (life)
1958 Eldorado Brougham 615
1998 Deville d'Elegance
1955 Eldorado #277
1964 Studebaker Commander
2012 Volt
CLCMRC benefactor 197
