‘61 sway bar links
Started by David Greenburg, September 14, 2021, 12:15:01 AM
David Greenburg
I'm replacing the sway bar links and bushings in my '61. The NORS Moog replacement link "tubes" in the kit are about 1/8" shorter than the originals.  It seems to me that this should not make a difference in the performance of the bar, although I'm not a front end expert.   It would also be possible to reuse the original "tubes" if necessary. They seem straight and intact. Anyone else encountered this?
David Greenburg
'60 Eldorado Seville
'61 Fleetwood Sixty Special
savemy67
Hello David,
If the replacement kit you bought includes all the components - bushings, washers, tubes/sleeves, bolts, nuts - the tubes/sleeves in the kit may be sized 1/8" shorter based on the measurements of all the other components.
If all the new components measure the same as all the old components, you will probably be OK with either of the tubes/sleeves from a practical standpoint.  However, the longer tube may make installation more difficult.
Keep in mind that after you have installed the kit, you may not be able to fasten the nut properly until the weight of the vehicle is on the ground, compressing the components.
Respectfully submitted,
Christopher Winter
Christopher Winter
1967 Sedan DeVille hardtop
David Greenburg
Hi Christopher:
You may well be right, or it may be that 1/8" doesn't matter and they use one kit to fit a bunch of different cars. Despite being older Moog parts, the same kit apparently fits a bunch of newer makes as well.  At any rate, the kit does include the bolts, washer and all, and even with the shorter tube, I did have to use a floor jack to compress things enough to get the bottom nut started. So all is good.  Except the noise I was hoping to eliminate is still there.
David Greenburg
65 caddy
Mike 65 caddy I had the same problem but my new sway bar links were to long so that I couldn't push the sway bar up high enough to put them in . I just used the old tubes witch were ok and the rubber bushing and washers from the new kit That was the only thing on the old  parts that were bad.
