67 DEVILLE STEREO BENCHTEST
Started by TomB, October 14, 2021, 11:47:48 AM
TomB
Hi all. Trying to benchtest my delco stereo but need to know where to supply 13 volts (the car is 100 miles further down the road, so no way to test the wires. In the attached picture it seems obvious that 4 of the 5 clustered pins are properly assigned (2 for speakers, 1 for antenna up and 1 antenna down. Is the 5th pin for 13 Volts. And is the grey wire on the picture also 13 volts? and ground through the casing?
Thanks, Tom
V63
The grey wire is typically for the illumination.
