Founded 1958
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Forum Rules
Calendar
Login
Register
CLC Home
Forum Rules
General Discussion
(Moderators:
Lars Kneller 8246
quadfins
Barry M Wheeler #2189
Bill Hedge CLC 14424
Starting a 6-volt car with jumper from a 12-volt car?
All Cads
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Starting a 6-volt car with jumper from a 12-volt car? (Read 445 times)
jdemerson
1952 Cadillac 6219X Vermont -- Emerson
Very large collection of Cadillac sales brochures
CLC Number: 26790
Name: John D Emerson
on:
October 15, 2021, 09:05:10 AM »
This topic has been discussed, but the results are mixed and sometimes conflicting.
Suppose a 6-volt Cadillac is at a show an hour from home, and the battery goes dead (maybe the lights were left on). The car ordinarily starts quickly. No other 6-volt cars are around. Is there a procedure for safely jumping it from a 12-volt car without causing any damage?
From discussion in the Forum, here is a possible response:
1. Do not have 12-volt car running when jumping. All lights and accessories off in both cars.
2. Connect for several minutes with the key of 6-volt car off.
3. Then try to start with key of 6-volt car; as soon as it starts pull off the jumper cable.
Is this likely to work? Is it reasonably damage-proof? Can someone improve on it?
John Emerson
1952 Cadillac Sedan 6219X
Last Edit: October 16, 2021, 08:20:20 PM by jdemerson
Logged
John Emerson
Middlebury, Vermont
CLC member #26790
1952 Series 6219X
http://bit.ly/21AGnvn
Jay Friedman
Re: Starting a 6-volt car with jumper from a 12-volt car?
Reply #1 on:
October 15, 2021, 09:31:16 AM »
I've started 6v cars using jumper cables with a 12v battery several times. With all accessories in the 6v car off, connect the 12 battery to the 6v battery. Immediately start the motor and then disconnect the cables quickly. Since the 12v jumper battery is only connected briefly, I've never had any harm done.
Logged
1949 Cadillac 6107 Club Coupe
1932 Ford V8 Phaeton (restored, not a rod). Sold
Decatur, Georgia
CLC # 3210, since 1984
39LaSalleDriver
Reply #2 on:
October 15, 2021, 01:06:05 PM »
I like to keep this handy quick reference chart that i made on my phone for those "just in case" moments. Fortunately, I haven't had to jump my car in a long, long time.
Logged
Jon Isaacson
(formerly USNTar)
1939 LaSalle 5019
Art Gardner CLC 23021
Reply #3 on:
October 15, 2021, 04:50:11 PM »
One thing is for certain -- it won't damage the 6v starter. I have converted a good number of 6v cars to 12v and just left the 6v starter in place. It works fine. Sure, in the very long run i might reduce the life of the starter a tad. But not worth changing.
Any bulb is at risk of blowing. So turn everything off, as noted elsewhere...
Logged
Art Gardner
1955 S60 Fleetwood sedan (now under resto)
1949 S60 Fleetwood sedan (restored 30+ yrs ago)
1958 Eldo Seville (2/3 done)
wrench
CLC Number: 27930
Reply #4 on:
October 15, 2021, 09:46:56 PM »
I’m still running 6v on my ‘51. I have used a 12v jump box on occasion. I turn off all the stuff and just jump it. I do hustle to get the thing disconnected once it starts, but that’s about it.
In theory, if you have a dead/down 6v batt and you hook up a 12v source, that 12v is never gonna reach past the batt. The dead batt is gonna suck down the voltage for a good while. I’ve never hooked a meter up while jumping, but I have charged a lot of batteries after starts while monitoring voltage. Once you kick that starter into the loop, overall system charge drops quite a bit under load.
Current definitely leaves the battery faster than a Gen or Alt can fill it back up.
Logged
1951 Series 62 Sedan
1969 Eldorado
1958 Apache 3/4 ton 4x4
2005 F250
2014 FLHP
2014 SRX
jdemerson
CLC Number: 26790
Reply #5 on:
October 16, 2021, 07:43:19 AM »
Jay, Jon, Art, and Jim,
Thank you for these most helpful responses. I've taken Jon's diagram/instruction list, printed it, and added to my operator's manuals (one in glove box and one at home).
This is one more example where the Forum is exceedingly helpful! Thank you!
John
Logged
John Emerson
Middlebury, Vermont
CLC member #26790
1952 Series 6219X
Print
Pages: [
1
Go Up
« previous
next »
General Discussion
(Moderators:
Lars Kneller 8246
quadfins
Sitemap
1
2
3
4
5
6
7
8
9
10
11
12
13
