Author Topic: 1969 cruise control  (Read 361 times)
Offline warrenwortman
  • Name: Warren Wortman
1969 cruise control
« on: October 22, 2021, 11:41:54 AM »
It sounds like cruise control on a 1969 Deville is a lot of maintenance Mine doesn’t work now Iwas thinking of trying to get it working Now having second thoughts
Opinions??
Offline 69Deville
  • Name: D Mirrione
Re: 1969 cruise control
« Reply #1 on: October 22, 2021, 05:22:33 PM »
I added it to my 69 Deville a few years ago. Using the shop manual, I bought all of the components from ebay and few other places. I was fortunate that everything worked as intended when I installed everything.
I'd check the switch that is mounted up by the top of your brake pedal to make sure it is aligned properly. If not, it will not engage as it will think you're applying the brakes.
Does the green light come on when you push the switch down to "Auto"?
1969 Cadillac Deville Convertible
All Cads
