All Cads
Author Topic: 1955 Cadillac w/hydrovac bleeding procedure  (Read 621 times)
Offline salvatore1159
  • Name: sal Bitonti
« on: November 27, 2021, 11:46:37 AM »
Looking for brake bleeding on 1955 75 series
Offline Dave Shepherd
Re: 1955 Cadillac w/hydrovac bleeding procedure
« Reply #1 on: November 27, 2021, 12:58:26 PM »
If no shop manual, Google is loaded with the how to sequence.
Offline Big Fins
  • CLC Number: 22631
  • Name: John Serio
« Reply #2 on: November 27, 2021, 04:13:44 PM »
'Should' be the same as hydraulic. R/R, L/R, R/F, L/F.
The master should respond the same way as a vacuum controlled master.
Current:
1976 Eldorado Convertible in Crystal Blue FireMist with white interior and top.
1969 Fleetwood Brougham in Chalice Gold FireMist with matching interior and top.
Past and much missed:
1977 Brougham de Elegance
1972 Fleetwood Brougham
1971 Sedan de Ville
1970 de Ville Convertible
1969 Sedan de Ville
1959 Sedan deVille
« Reply #3 on: November 27, 2021, 05:24:21 PM »
Actually there  is a procedure  for bleeding the power brake unit, 2 bleeders involved, then onto the wheels as you mentioned.
Offline Big Fins
  • CLC Number: 22631
  • Name: John Serio
« Reply #4 on: November 28, 2021, 03:45:32 AM »
It wasn't stated as to whether the Hydro-Vac unit was being bled. I 'assumed' the OP meant the wheels.
Current:
1971 Sedan de Ville
1969 Sedan de Ville
1959 Sedan deVille
« Reply #5 on: November 28, 2021, 06:41:09 AM »
Yeh, I see what you mean.
Offline Jeff Rose CLC #28373
  • CLC Number: 28373
  • Name: Jeff Rose
« Reply #6 on: November 28, 2021, 07:02:43 PM »
You don't bleed it like regular brakes. Need to bleed the booster 1st.
Jeff R
« Last Edit: November 28, 2021, 07:05:27 PM by Jeff Rose CLC #28373 »
Jeff Rosansky
CLC #28373
1970 Coupe DeVille (Big Red)
1955 Series 62 (Baby Blue)
Dad's new 1979 Coupe DeVille
