1955 Cadillac w/hydrovac bleeding procedure
Started by salvatore1159, November 27, 2021, 12:46:37 PM
salvatore1159
Dave Shepherd
If no shop manual, Google is loaded with the how to sequence.
Big Fins
'Should' be the same as hydraulic. R/R, L/R, R/F, L/F.
The master should respond the same way as a vacuum controlled master.
Current:
Past and much missed:
1977 Brougham de Elegance
1972 Fleetwood Brougham
1971 Sedan de Ville
1970 de Ville Convertible
1969 Fleetwood Brougham
1969 Sedan de Ville
1959 Sedan deVille
Dave Shepherd
Actually there  is a procedure  for bleeding the power brake unit, 2 bleeders involved, then onto the wheels as you mentioned.
Big Fins
It wasn't stated as to whether the Hydro-Vac unit was being bled. I 'assumed' the OP meant the wheels.
Current:
1971 Sedan de Ville
1969 Sedan de Ville
1959 Sedan deVille
Dave Shepherd
Jeff Rosansky CLC #28373
#6
You don't bleed it like regular brakes. Need to bleed the booster 1st.
Jeff R
Jeff Rosansky
CLC #28373
1970 Coupe DeVille (Big Red)
1955 Series 62 (Baby Blue)
Dad's new 1979 Coupe DeVille
