Author Topic: 1955 wipers  (Read 514 times)
Offline G.Lucas #25354
  • CLC Number: 25354
  • Name: G.Lucas
1955 wipers
« on: November 28, 2021, 05:59:54 PM »
Hell, when I rev my motor my wipers seem to come on. Switch is off on the dash, maybe I have something connected wrong? However I do not have the manifold vacuum connected to the 3 way valve on the firewall. Any thoughts? Thanks, George.
Offline Jeff Rose CLC #28373
  • CLC Number: 28373
  • Name: Jeff Rose
Re: 1955 wipers
« Reply #1 on: November 28, 2021, 06:58:15 PM »
Some vacuum is getting through. Either the valve in the wiper motor is leaking or the system is out of rig. The wiper motor valve is controlled by a cable. I would manually close the valve on the wiper motor to see if that helps. If it does then adjust the cable.
Jeff R
Jeff Rosansky
CLC #28373
1970 Coupe DeVille (Big Red)
1955 Series 62 (Baby Blue)
Dad's new 1979 Coupe DeVille
Offline Hillbillycat
  • 1956 Sedan Deville
  • Name: L.Stark
Re: 1955 wipers
« Reply #2 on: November 29, 2021, 03:17:11 AM »
I had that on my 56 when one of the rubber valves/gaskets inside the control unit on the lid of the washer  jar was cracked due to age.
Sounds like you need to replace these.
But I know 56 is slightly different from previous.
