Author Topic: 1929 Gas Tank Removal help  (Read 820 times)
Offline grwell
  • CLC Number: 14186
  • Name: Geoff Weller
« on: November 30, 2021, 12:05:11 PM »
Looking for suggested process to remove/shift tank to remove sender unit
Offline Chris Cummings
Re: 1929 Gas Tank Removal help
« Reply #1 on: December 06, 2021, 02:15:20 PM »
Is there an inspection plate at the rear of the body floor?
Offline grwell
  • CLC Number: 14186
« Reply #2 on: December 07, 2021, 06:50:58 AM »
Chris, Thank you for the suggestion, however the tank is rearward of the body essentially under the truck without an access plate on the body that I can see.
« Reply #3 on: December 07, 2021, 02:28:41 PM »
It would be tucked under the bottom edge of the seat back cushion like in this photo.
« Reply #4 on: December 07, 2021, 02:30:53 PM »
What body style is your car?  Unless it's a seven-passenger sedan, you'd have to take the seat back cushion out to be able to work on the sending unit through the inspection port (if your car has an inspection port).
Offline grwell
  • CLC Number: 14186
« Reply #5 on: December 08, 2021, 08:22:47 AM »
Dual cowl sport phaeton.  Tank is reward of the body.
« Reply #6 on: December 08, 2021, 10:35:42 AM »
I see.  Is your car like this one?
If so, do you know whether there is an inspection plate under the built-in trunk?  I'm just looking for a way to save you dropping the tank.
I would expect an inspection plate on all of the cars from these years, so that the sending unit wires could be connected or disconnected  with the tank in place.  Otherwise, you'd need a long, loose length of wiring harness to allow for connecting the sending unit with the tank on the floor.
On my 1930, to remove the (empty) tank, the first step is to go through that inspection opening and disconnect the fuel gauge sending unit wiring.  Then remove a vent tube between the tank and the upper part of the filler pipe, disconnect the fuel lines at the tank (mine has two), disconnect the tailpipes at the muffler, undo the clamps holding them, and remove the tailpipes (mine is dual exhaust).  Place a jack or dolly underneath the tank.  Then there are three bolts (two in front and onw in back) that fasten the tank to frame cross members.  Undo those and the tank can be lowered and removed.
Hope that helps.
