Typically they seize from moisture getting in. Yes, if you remove it, it might be salvaged with Cleaning, lubrication and encouraging movement. The unit is specific for 2 door and left or right, but cover as much as 1971-78
I have also ‘skinned’ a 4 door version and inserted its internals into the 2 door required housing.
