deville 67 mystery parts
Started by TomB, December 04, 2021, 03:55:56 AM
TomB
Deville is almost finished. But seems to be ending up with a bunch of small parts that don't seem to fit anywhere. Find attached picture with numbers, who knows them? Thanks!
cadillactim
5 looks like trunk lip molding extensions that mount on quarter panels. 6 looks like front fender pieces that mount on back of fender at the top in the door hinge area. 7 looks like inside door handle trim that mounts behind door handle.
Tim
Tim Groves
TomB
Thanks Tim, that is half of the list resolved, one part at the time. Enjoy your weekend.
Tom
DeVille68
nr 3 looks like a brake line t-holder on the rear axle.
E Masters
#4
1 is attached to the inner side of the door. The inner part of the arm rest is secured by a screw under the handle. It's screwed down into the slit and helps to secure the door card to the door.
Edit: The screw goes in under no 7
