Author Topic: cadillac 500 oilpan  (Read 431 times)
Offline pepsiii1988
  • Name: Jimmy
cadillac 500 oilpan
« on: December 04, 2021, 02:40:54 PM »
Should change the rear oil seal on the engine, my question is can you remove the oil pan without having to lift the engine? It is a cadillac de ville rwd 1976
Jimmy Bergman
Re: cadillac 500 oilpan
« Reply #1 on: December 04, 2021, 07:09:45 PM »
Yes, just pull the exhaust crossover, and lower the drag link. The procedure is fully described in the FSM
Offline pepsiii1988
  • Name: Jimmy
« Reply #2 on: December 06, 2021, 06:44:23 AM »
ok thanks, I have already done that but how do you get the oil pan down because it takes in both the front beam and the flywheel at the rear, or should you take it down in some special direction?
Jimmy Bergman
Offline The Tassie Devil(le)
  • Administrator
  • CLC Number: 18992
  • Name: Bruce Reynolds
« Reply #3 on: December 06, 2021, 06:46:19 PM »
Don't forget to remove the dipstick.
But, by following the Factory Shop Manual (FSM), you shouldn't have any problems.
PS.   You do have a FSM?
Offline pepsiii1988
  • Name: Jimmy
« Reply #4 on: December 07, 2021, 08:50:05 AM »
Yes I have FSM if you mean factory service manual?
Jimmy Bergman
  • Administrator
  • CLC Number: 18992
« Reply #5 on: December 07, 2021, 04:23:51 PM »
Yes.   In that case, it should describe exactly what you need to do.
Including the reinstallation.
Offline Caddylackn
  • Name: D Zavack
« Reply #6 on: December 08, 2021, 12:53:41 PM »
With the pan down, be sure to remove all the nylon timing gear teeth chunks from the bottom of the pan and clean the pick up screen of debris
'61 Fleetwood 60- owned for 31 years
'61 Series 62 2-door - sold
'64 Series 62 2-door -sold
'67 Sedan De Ville - sold
'74 Eldorado Convertible - sold
All Cads
